Before you remove the batteries do two things.
1: Using red (and optionally black) paint or nail polish
Paint all the POSITIVE wires RED.. (if using black as well that's the negative side DO THIS before you disconnect. if you get a bit of paint on the batteries not a bad thing.
NOTE with six volt pairs ignore the battery to battery jumper. Take it with you when you move to storage.
Then PHOTOGRAPH the batteries as installed.
Once paint/nail polish dries
Disconnect NEGATIVE wires (if more than one tie them together with string)
Then the Positive (likewise tie if more than one) and insulate.. A styrofoam cup. may work well for this. or a sandwich bag (double bag) with a rubber band or bungee tie
Next: There are many myths about storing batteries on something like a garage floor.. DO not believe them.. Oh they were valid say 50-80 years ago but not today.> Still set the batteries on some scrap wood (plywood is good) the reason THE REAL REASON is often there is a little acid on the outside of the battery and this can damage whatever they sit on. SCRAP wood is very very very inexpensive (FREE) and thus the preferred surfact to destroy.
Six volt pairs.. Pair them (WHy you took the jumper(s) with you
Hook up a Battery tender or .. however many you need (Get one that can handle say 4 banks) and see you come spring.
My battery tender can do 20 amps.. or <2 amps (less than) Depending on the mode 70 if I need to give my car a jump.
