wrinkled wall paper?
emzee
Just wondering if anyone had a solution for wrinkled wall paper. It's wrinkled around the edges of the door hardware. I was thinking of getting it moist and trying to smooth it that way?
4 REPLIES 4
emzee
We're going to try the heat method thanks!
imgoin4it
The factory told me they use a heat gun to heat it and smooth it out. I think it actually shrinks a little. I fixed a small spot with DW hair dryer. Worked great l
Howard,Connie,& Bella,
One spoiled schnauzer
2007 Newmar KSDP
4dr Jeep Wrangler
emzee
GENECOP, you are right, didn't work. I think it needs heat to do any moving. Maybe better leaving it alone.
GENECOP
That will not really work. Wrinkles are caused by improper install, very difficult to just smooth out. If it is large enough cutting or slicing and flattening could work...
