โMay-21-2017 01:38 PM
โMay-21-2017 05:52 PM
richheck wrote:
Last year when the Wallys first came out I purchased two. At that time I was instructed to connect each to a 1000.2 dish to allow the Wallies to download the updated software before trying to connect to my Pathway X2. After doing as instructed to get the software updated I had no problems connecting to the X2
โMay-21-2017 05:23 PM
โMay-21-2017 05:11 PM
Bill.Satellite wrote:
Are you trying to use the 2 receiver setting and going to the 72 satellite? Did you get a successful check switch? If you are trying to use the 1 receiver setup with 2 receivers you must connect 1 receiver to the main output and preform a check switch. You will then need to connect the other receiver to that same cable and do a check switch on that receiver. Once you have each running successfully by themselves you will be able to connect both.
โMay-21-2017 03:58 PM
โMay-21-2017 02:52 PM
โMay-21-2017 02:50 PM
โMay-21-2017 02:41 PM
2naEagle wrote:
Mine did that.
Push Sat(on the side of the remote)/Skip Back/Recall/Skip Back.
โMay-21-2017 02:31 PM
