Dish Network Question
siggyd777
Can I get HD reception using a new WALLY receiver and my RTT-12B-Sdi
in motion dome ?
Thanks for your replies, Siggy
Happy Trails
Siggy & Ursula
2011 Dutch Star 4020,ISL 400,Compr.brake,FTL XCR,IFS
Allison MH3000
2015 Jeep Cherokee,4x4 Active Drive II,V6 , Brake Buddy,Roadmaster Sterling,
Camping since 1975 Pop-Up,1986 22Ft.TT,1999 Gas MH,2005 KSDP,
2011 DSDP,FMCA 368283
4 REPLIES 4
Bill_Satellite
You have that right. The domes do still work with DirecTV but only in SD. The older domes will get HD with Dish but most of them can no longer lock onto the Dish satellites due to changes Dish made to their broadcast signal. So......IF your antenna will lock onto the Dish satellites (highly questionable) then you will be able to get HD. If it cannot, you will get nothing at all.
Can't we all just get along?
siggyd777
Well, the dome is working fine with an H24 & DirecTV,but I only get
SD. But I like to know if I can get HD with Dish . I do not need the In-Motion. I guess ,I need a good friend with a Wally receiver to make some tests with the DIP switches set for DISH.
Thanks for all replies.
Siggy
Happy Trails
Siggy & Ursula
Allison MH3000
Bill_Satellite
in motion dome ?
YES! That is if the dome is working! It might not be able to lock onto the Dish satellites (3 of them) due to the age of the antenna and changes Dish make to their broadcast signal.
lryrob9301
Maybe, can you receive DISH Network now with this dome, if yes then you can receive DISH HD with a Wally. If no or you are not sure read the attached.
DISH Network 8PSK Transition
