Laptop power test with killawatt
JiminDenver
I thought I had gotten away from this topic since I replaced the netbooks with 2 in 1 windows tablets. Then I received back a 17 inch HP that I had given Mom a few months before she died.
Now the tablets can charge off of a USB or 120v. The Laptop is 120v with the charger output rated for 19.5v, 2.31a, 45w max. The first thing I tested was the draw with just the power brick plugged in, it was0.0w with a occasional blip of .03w.
I plugged in the laptop sleeping and it drew a average of 12.9w around 75% charged. I'll have to see what it draws off/on and fully charged. I can see the charger turning off when at 100% and off.
I turned on the computer and it drew 20-25w depending on what it was doing. Downloading a video or spinning up the DVD was higher but usually 20-21w. Laptop on but sleeping pulls .4w
I took the battery out and started the computer, after it started it averaged 10w and would draw as much as 16w briefly depending on what you do.
So if I keep the slab of granite, I won't be carrying it around which means I don't need the battery to be charging all the time. 10-16w for a 17 inch, quad core is pretty doable.
I'll put the battery back in and see what it does fully charged.
2011 GulfStream Amerilite 25BH
2003 Ford Expedition with 435w tilting portable/ TS-MPPT-45
750w solar , TS-MPPT-60 on the trailer
675 Ah bank, Trip-lite 1250fc inverter
Sportsman 2200w inverter generator
5 REPLIES 5
strollin
In order for the laptop to consume anywhere near the max power rating of the brick, the battery would need to be nearly drained and charging, the display on full brightness, speakers playing audio at full volume, the hdd seeking and writing, the DVD being accessed, the USB ports powering peripherals AND need to be running hot so the fan would be at full speed.
Most likely no one would ever use that much power, but it's possible, so it must be allowed for.
Me, her, 2 boys & 2 girls
'05 Chevy 2500HD LT 4x4, D/A
Reese Dual Cam HP
'04 Wilderness Advantage 290FLS
Twin Honda 2000s
"I'd rather wear out than rust out!"
See our pics here
Naio
My current laptop follows the (evil!) Apple model of having no user-removeable battery ๐Ÿ˜ž
3/4 timing in a DIY van conversion. Backroads, mountains, boondocking, sometimes big cities for a change of pace.
JiminDenver
The 20-25 watts was when the battery was 75% and charging. Once fully charged and running the draw was very similar to not having the battery in at all. So once the battery is charged the brick only checks its status when the watts blip up to 0.03.
There are a few reasons to remove the battery even though it seems the brick stops charging it. First is when batteries do get old they can require charging all the time because they are never full. Second is I believe it's advised to remove the battery if not needed for long periods.
Naio
Good experiments!
Was the 20-25w when it was 75% charged (and charging) or 100%?
Would be interesting to know if it uses that much just maintaining a top charge.
MrWizard
Moderator
Moderator
Typical example of what I was saying in a recent inverter thread
Laptops don't us the max power rating on the brick
They use very little power most of the time
I can explain it to you.
1997 F53 Bounder 36s
