Lenovo G580 stuck on boot screen.
mileshuff
Have a Lenovo G580 that will only boot to a boot screen menu asking which device to boot to. No matter what I select it returns to the menu. Won't boot to hard drive, CD or USB. I can hit the tab key which takes me to another menu where I can select setup. Doing that results in asking for a bios password. I have never ever entered any password. This PC was working fine with Windows 7 64Bit. Shut it down and it had been left off for several months.
Researching online tells me the issue is related to secure mode, UEFI. Have found a few others with the same laptop with the same issue but no solution. Found talk about clearing the bios by shorting a cap on the motherboard but cannot find where. Tried removing cmos battery and shorting the contacts there to no avail.
Any ideas?
2014 Winnebago 26FWRKS 5th Wheel
2007.5 Dodge 2500 6.7L Diesel
2004 Dodge Durango Hemi 3.55 (Used to tow TT)
5 REPLIES 5
MrWizard
Moderator
Moderator
I think the Bios password is NOT your not login password (that you have never set)
It is something different
On the web, you can download an ISO file called the "Ultimate Boot CD"
http://www.majorgeeks.com/files/details/ultimate_boot_cd_(ubcd).html
This might help you get it booted,
I can explain it to you.
1997 F53 Bounder 36s
mileshuff
If I try to boot with a Windows 7 install disc I get the following error:
Secure Boot
Image failed to verify with ACCESS DENIED
I'm positive the issue is the bios reset itself to some defaults with the secure boot mode on. Only way to clear it is from within the bios. But the bios set some sort of default password (I never entered any). Removing the cmos battery doesn't clear the issue nor the password request.
Charlie_D_
Had similar issue with my Toshiba. Shut it down, unplugged it, removed battery and held off button for 15-20 seconds. Reinstalled battery, plugged in and turned on.
Enjoying Your Freedom?
Thank A Veteran
Native Texan
2013 Prime Time Crusader 330MKS
2018 Chevy 2500 D/A Z71 4x4 Offroad
2006 Holiday Rambler Savoy 33SKT-40,000 trouble free miles-retired
2006 Chevy 2500 D/A-retired
2013 Chevy 2500 D/A-retired
MNtundraRet
Navigator
Navigator
When asking for password have you tried just hitting the "enter" key, or typing in "password" and hitting the "enter" key?
If this fails, Windows 7 may be installed in protected section on the hard-drive. Pressing the correct function key on start-up may get you to the point the computer can reformat and re-install Windows 7 to the point the computer was brand new.
This works if Windows 7 came installed on your computer. Read the information that came with your computer for the correct reset procedure and Function key that works for your model. I needed to do this on my Asus gamming laptop (circa 2010) when Microsoft Windows 10 tried to download at the same time Windows 7 updates were downloading.
If you Google your computer's brand & model you can find the information for re-setting you specific computer model on the internet.
Mark & Jan "Old age & treachery win over youth & enthusiasm"
2003 Fleetwood Jamboree 29
sch911
One possibility: Sounds like hard drive boot sector corruption. Run the system recovery tool by booting the Win 7 DVD and tell it to repair the boot sector.
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
