โOct-13-2018 04:58 AM
โOct-22-2018 02:55 AM
โOct-21-2018 06:05 PM
โOct-21-2018 02:03 PM
โOct-20-2018 09:31 AM
Keep in mind, after you create the custom PIN, you'll need to make sure the SIM is unlocked prior to putting it into the Mobley. Or else the Mobley will not provide internet access until you log into the Mobley using the Wifi Manager and manually enter the PIN. That's a pain and not worth it. I assume if the M1 has the option to lock the SIM it should have the option to unlock it as well.
energyx wrote:
Thanks for this. Just called in and got both within 2 minutes. I'll test out in a bit.
Update: I put a Mobley 1.0.3 locked SIM into an old ATT GoPhone Lumia Windows phone and set the PIN using the PUK after 3 failed tries. Went to the SIM Lock settings and disabled the PIN. Put it into a Velocity that was asking for a PIN before and it fired right up without one. Now to see if the Mobleys will re-lock. At least we do have a way to get around the lock, if needed.
โOct-19-2018 11:18 PM
I actually didn't have any hold time. I called 1 (800) 331-0500. When the automated voice came on and asked what it could help me with, I said, "Get a PUK code." The voice said, I can help you with a SIM card, please hold. And it transferred me to the rep who gave me the codes.
โOct-16-2018 07:15 AM
โOct-15-2018 06:32 PM
When I log in to my AT&T account (I only have the Mobley with them) and click on manage my device and features it says: "My current features:
You currently don't have any features on your account"
and it says this:
"See device options
Upgrade device See optionrightArrow
Suspend device See optionrightArrow
Unlock a device See optionrightArrow
Manage data See optionrightArrow
Update caller ID info See optionrightArrow
See accessories See optionrightArrow
Manage Sponsored Data"
โOct-15-2018 05:38 PM
โOct-13-2018 05:48 PM
โOct-13-2018 04:36 PM
magicbus wrote:
Did the Unite ever work or did you just buy it?
โOct-13-2018 03:27 PM
โOct-13-2018 03:01 PM
โOct-13-2018 02:36 PM
โOct-13-2018 02:25 PM
jcpainter wrote:
Does it work if you put it back into the Mobley?
โOct-13-2018 08:39 AM
BluStem wrote:
Went and moved my SIM from my Mobley to my Unite and get a message that the SIM is PIN locked. Had a notice to enter a PIN.
The end of SIM swapping?
I never had this before, it just worked.
