MODEM / ROUTER Question
DD716TED
Next week, Xfinity will be replacing my older Comcast / Xfinity modem / router with a new unit.. It was requiring a reset almost every week. When they do this, can or will they transfer the WiFi security code from the old modem to the new one OR will I have to enter a new code on all my WiFi devices like cell phone, Samsung Pad, laptops, tv's, printers, etc.. Had to ask..
19 REPLIES 19
theoldwizard1
I just went through this. Unfortunately my new modem/router (Surfboard SBG8300) would not allow an SSID of less than 6 characters and my old one was 5 !
Do you know how many devices 6 grandchildren and their parents have !!!
wa8yxm
Can: yes
Will: ??????
however you can do it
To do so you need to log in as adminstrator to the Router
NOTE yoru current SSID and PSK
Make the changes
Save and in some cases restart (other you don't need to restart)
As an example My Spectrum router came with Spectrum122342r or ome such.. It's now SpectrumYXM and the PSK is.. Well ********** Same as the phone which is SamsungGalaxyYXM
(Get the feeling that the suffex of my ham call is "YXM")
makes it easy to pick my router out of 20 other Spectrum routers or Samsung Galaxy phones.
Oh the other router in the house (needed for some hardware that does not like the Spectrum) is Snafu.net... if you don't know what it means "Situtation Normal, All ****** UP.
Lantley
Someone (installation tech or yourself)
Can manually set the password (SSID) to whatever you want.
In this case use can simply program the new modem with the same password(log in data) as the old modem.
philh
If it's a new unit, highly likely it will require each device to be reconnected.
fj12ryder
You should be able to use the old security code on the router/modem. I replaced our old router and simply used the old password in place of the default. No biggie. Of course everyone hates me because I use a 20 character password with letters, numbers, Caps, and special characters. ๐Ÿ™‚ So I didn't want them all PO'd because they had to redo their network access.
Howard and Peggy
"Don't Panic"
