winegard to dish
gary_r1
I am wanting to switch to dish.
Where can I find how the cables are run In the keystone 5er.
I know the aerolite we owned had a good manual on all oem products
installed on the trailer.
However the 5er did not come with such a manual I have looked all over the net and no luck. THANK YOU FOR THE HELP.
3 REPLIES 3
wingsfan20
I installed a separate cable outlet specifically for the Dish cable. No worries about TV amplifiers etc.
Jim :W
2007 Silverado 3/4 LTZ Crew Duramax/Allison
2008 Keystone Cougar 311RLS
Bill_Satellite
Forgetting about the service provider, what antenna do you use now and is this an antenna you have used successfully in the past?
Can't we all just get along?
orlandimal
I have a keystone 5er and tried to find the same information that you are looking for with absolutely no luck. I resorted to pulling off the cable wall plates and removing the stereo to figure out what cables go where. If you join the keystonerv.org site which is similar to this site someone could probably provide you info with regards to your exact trailer.
2008 Silverado 2500HD, Z71 off-road, Z85 towing
2005 Keystone Hornet 245RKS 5th Wheel
