Winterizing
Bob_Barrett
I am posting to get some imput on winterizig my camper . Last year i used the red non-toxic antifreeze , and took forever to get it out one we started camping again . This time im trying the air method , and seem like the hotwater heater gurgles forever , I dont want to ruin anything , How do you winterize ? Is the air method trustworthy ?
16 REPLIES 16
BB_TX
Don't know why it took so long to get it out unless you put antifreeze in the fresh water tank. Just pumping it thru the water lines and it will clear out very quickly when you hook back up to a fresh water source.
And winterizing the water heater means draining it, not putting in antifreeze or blowing it out.
boogie_4wheel
Pull the drain plug/anode rod to drain the water heater.
Go to backside (inside the trailer), and actuate the water heater bypass valves.
Run the water pump a few seconds to clear out its little piece of line.
Attach air to city water connection.
Open low point drains and blow water out. Finger tight the caps back on.
Open each faucet (kitchen, bathroom, shower) and toilet to blow them clear.
Do the low point drains a second time for the fun of it.
Open all faucets.
Pour a little antifreeze down each drain, enough to fill the trap plus some to make it to the holding tank. Pour a little down the toilet.
Do this to mine every year, sees -20*F.
2005 2500 Cummins/48RE/3.73, QCLB, 4wd, BigHorn, Edge Juice w/ CTS + Turbo Timer,Transgo Shift Kit ISSPro Oil and LP pressure gauges, GDP 20/2 filters, Custom Diesel Steering Box Brace
'10 Forest River Shockwave Toy Hauler 21'
Honda EU3000I Genny
