2019 JL wrangler 2 door
klutchdust
Anyone set one up for towing yet. My Jeep is on order and will arrive mid May. My concern is the wiring for the taillights. Haven't found a harness yet that plugs in, the only one so far requires splicing. Splicing into a brand new vehicle makes me itchy.
21 REPLIES 21
klutchdust
Tom/Barb wrote:
I don't know how you would place an extra bulb in a LED assembly that does not have room for it.
2019 will have LED assemblies for tail lights.
Get a boat trailer wiring KIT, it will have all you need to make a wire harness. Run the 4 pin tape thru the Jeep to the tail gate, place a 4 pin plug on that end where you can plug in your extra 2 lights.
I made a small bracket that clips over the top edge of our gate one each side to carry the lights.
Your jeep will not be cut/ altered in any way.
use a 7 pin to 4 pin adaptor on your motorhome, PLUG and simply plug your jeep harness in to it.
No more fiddling with charge wires, diodes, batteries, bulbs or any thing. just plug and go.
I'll built the harness if you like,,, PM me for phone and e-mail.
Thanks for the offer. Yes, it will have led lighting, itโ€™s actually an option or comes with it since I ordered the Jeep with steel bumpers. I forgot about that part. I can handle the wiring part, did a few before.
Tom_Barb
2000 Newmar mountain aire 4081 DP, ISC/350 Allison 6 speed, Wrangler JL toad.
klutchdust
rk911 wrote:
don't splice...run a second, independent wiring harness and install two extra bulbs in the taillight assembly. EZ-PZ.
Thatโ€™s how I wired my 08 Jk. Sounds like another afternoon project.
rk911
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
Tom_Barb
WE have a JK wrangler but I got so tired of bad connection, blown diodes, that I finally purchased a boat trailer wiring kit and built a tow harness with two LED lights from NAPA.
It simply clips into the tail gate opening, and had nothing to do with the Jeeps harness. No more disconnecting the battery, just turn the key to unlock the steering and go.
dkreuzen
I just went through that for a 2019 JL. No plug in is available yet. You will have to splice.
Dennis
2012 Monaco Knight 36PFT
2019 Jeep Grand Cherokee Overland
2005 Jeep Wrangler Unlimited Rubicon on 2007 16' Car Trailer
mleekamp
We just picked up a 2000 Wrangler to do the same.
Contact eTrailer ... they seem to have the goods and the Tech folks to know what you need. I'd expect they are working on 2019 Jeep stuff now....and again, have great tech support before and after you buy.
**I only endorse eTrailer as I've used them in the past ... I don't get kickbacks!
