Hello everyone, thought I would give a bit of an update. Ended up selling our 2015 RAM limited dually and are now pulling our camper/boat combo with our welding rig which is a 2007 ram 3500 dually with 5.9 cummins and 6SPD G56 transmission, air bags, banks exhaust brake. Biggest issue I had going to the welding rig was making the decision as to use the Andersen ultimate or the reese goosebox. Unfortunately the reese goosebox wouldn't have given adequate clearance from my toolboxes when turning. So decided to go with andersens ultimate hitch made for trucks with flat beds. previous to this I have used a B&W companion since 2015.
First of all one of my major reasons going to the Andersen unit was weight.... after almost 4 years with the companion I DESPISED taking it in an our of my truck, used the skid steer however was still always a royal pain to take in and out. Having said that, I feel the B&W is likely the best made fifth wheel hitch money can buy.
comparing ease of hookup I would say the Andersen may edge out the B&W slightly. I only say this because the funnel makes backing up accuracy almost entirely on par with a fifth wheel jaw. The best part being once your close you lower the camper, slides onto the ball and its just a tee-handle which is all controlled form the ground, no climbing onto tire of truck to close jaws etc.
being a high pressure welder I am surprisingly impressed by the welds on the Andersen hitch. I DO NOT agree with the pinched tubes, in my world this is considered lazy fabrication. Properly cut/angled tubes would allow for a lot more surface weld. But at the end of the day its an insured product.... if it fails and dosent work its on them. Believe you me I was absolutely a skeptic when I first saw them come out, but being in the situation I am in the Andersen was essentially my only viable option. It tows well, installation takes 5 minutes max and the best part is I can take it out at the lake and lift the thing out without dismantling it. With the Andersen on the lowest setting the montana is still a bit nose high but not bad, and still quite comparable to my 2015 ram and B&W. Could let some air out of the bags but I don't think its that bad.
At this point, I would personally highly recommend this hitch setup, being that ive had alot of experience with goosenecks/fifth wheels, unless something crazy happens I don't forsee myself going back to a conventional fifth wheel hitch. Weight savings/ease of instsall/ease of hookup with the Andersen sells its self to me anyway, I suppose that could change the more miles I put on but I doubt it.
2015 RAM cummins 3500 dually Limited
2018 Montana high country
crestliner sportfish
