Dodge 3500 Diesel Tranny
miklman
I towed with a Ford F250 7.3 Diesel and the tranny went bad. While it was being rebuilt, I bought a Dodge Ram 3500 2002 to getaround in. For some reason it takes a while, 15sec., for it to go into DRIVE from PARK. Does this truck need a tranny too? Any ideas?
michael
6 REPLIES 6
larry_barnhart
My dodge did this from the beginning so I had it fixed. Return line from the radiator to the trannie had a check valve problem so it was draining. what a difference the repair made.
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
Passin_Thru
If it does it when cold but not when hot it has a thermostat that keeps it in low gears to warm up.
BarneyS
I have a 2002 F250 7.3L Diesel with 250,000 miles and the original transmission and torque converter. My trailer weighs just about 10,000lbs. It is still going strong but I do change trans fluids and filter every other year. Costs a little over $100 but seems to be paying off. ๐Ÿ™‚
Barney
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
wandering1
I had my tranny rebuilt on my Ford F250 7.3 Diesel at about 80k. From what I understand 40k is normal with a lot of towing.
HR
B_O__Plenty
make sure the fluid level is correct
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
Mark_Heisler
90% of the older dodge do this. what it is the torque converter is draining back.I have two dodge trucks that do that. what i do put in N for a sec then to drive.the tran pump does not pump fluild in park.
2003 dodge 2wheel drive diesel 375hp 750torque
2007 citation fifth wheel model 29bhs
to see pictures of my truck and fifth-wheel click on view profile
