air conditioner recall now not working
para1766
I have a 2016 premier bullet by keystone that had a wiring recall on a/c. I took it to service center and had recall fixed now a/c will not blow blow cool air. Compressor is kicking on but just warm air comes out. It is a 2016 and only been on two camping trips. Anyone with any ideas. Seeing as how the one year warranty just went out.
9 REPLIES 9
dougrainer
Dometic has a 2 year warranty. Doug
Chris_Bryant
The wiring recall has zero chance to mess this up- it is all done from inside- the Dometic has 2 power lines at the control box- one power in, the other power out to the thermostat. Keystone lust used one, connecting the thermostat power and box power together, which is not good. They basically had no reason to do anything on the roof unit.
-- Chris Bryant
Bill_Satellite
Take it back. Have them fix what they broke. They need to be your first contact!
Can't we all just get along?
Sam_Spade
Chris Bryant wrote:
The timing vis-a-vis the recall was just a coincidence .
Well you don't know that quite yet.
Partly because we don't know for sure that the compressor IS running.
๐Ÿ˜‰
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
Mandalay_Parr
An AC tech may be able to fix it.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
MEXICOWANDERER
Length of time elapsed between recall and dicovery?
MrWizard
Moderator
Moderator
unless they damaged a line
things DO happen
it should be taken back and checked
I can explain it to you.
1997 F53 Bounder 36s
Chris_Bryant
If the compressor is running but it is not cooling, it has a leak, and needs to be replaced. The timing vis-a-vis the recall was just a coincidence .
-- Chris Bryant
Sam_Spade
I think you should take it BACK to the place that did the recall repair. There is a good chance that they screwed something up in the process.....and the expiration date of your original warranty should mean nothing.
