Hello all,
I have a temp control ceiling vent fan. The open portion of the controls works without issue. But the fan doesn't run. I took it apart and while apart it runs, but when I put it together it doesn't run. I took it apart a second time and again while apart it runs. I assembled it while running and ran without issue, but a couple hours later I turned it off but it would not run again. Any ideas what is going on?
Thank you for your time.
