Batteries Will Not Take Charge
Lenny_K
I have a friend that has a Chinook Class B with two 12v batteries that will not take a charge over 13.4v even with a 40 amp battery charger attached. Needless to say they wake up in the morning to low battery beeping sounds.
Any ideas why they will not take over 13.3v charge.
Lenny and Ros
2009 Chevrolet Silverado 3500 LTZ Duramax 4x4 CC Dually, Banks Speed Brake
2012 Montana 3400 RL 680 Watts Solar, 440 Amps of Batteries, GP-ISW2000-12 Inverter, Trimetric 2020, EMSHW50C, Sailun Tires
20 REPLIES 20
Lenny_K
rk911 wrote:
Dakota98 wrote:
Are these Lead Acid or AGM ?
Are "all connections" clean ?
and if not maintenance free check the cells with a hydrometer. how old are the batteries?
I don't have a hydrometer with me and the doesn't have one either and I don't know the age of the batteries.
I've been after to have a load test done on them but he hasn't to date.
Lenny and Ros
Lenny_K
MEXICOWANDERER wrote:
If they are dead they will bubble vigorously at 13.4 volts. Dead meaning battery recycler time. Time to have them tested...
I'm thinking they are dead also but why will they not take a higher charge?
Lenny and Ros
Lenny_K
Lead acid and connections are clean.
Lenny and Ros
rk911
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
MEXICOWANDERER
Dakota98
I'm an expert in only one field....I believe it's somewhere in Kansas.
2000 / 22' SKYLINE NOMAD LITE
1998 DODGE DAKOTA / 5.2L= 8mpg.
2006 POLARIS ATV
1500/1200 Watt Champion generator
Yada Wireless Back Up Camera
1998 Dyna Wide Glide
USMC 68-74
