eBay Blue and Brown Out Cut-Out Receptacles
MEXICOWANDERER
Plug n Play Villainous Voltage Protectors
http://www.ebay.com/itm/282587373835?ul_noapp=true
5 REPLIES 5
MEXICOWANDERER
Different devices different sensitivity and vulnerability. A refrigerator motor can withstand 90 volts better than a roof air conditioner. And most power bricks start to unravel at less than 90 volts. Too high a number and the complaints start pouring in...design is always a compromise.
pianotuna
Nomad III
Nomad III
90 seems a little low for brown out protection?
Regards, Don
MEXICOWANDERER
I tried but the laptop tilted off the bed.
K_Charles
Could you make that picture a little bigger?
Lwiddis
Magical protection for $10 each. If it sounds too good to be true...
