eu2200 with eu2000
2oldman
Paired up a new Honda 2200 with a 5-year-old 2000, and it works fine. Actually, a 2200 with 2 other 2000s for a grand total of 6200w max.
With just 2 in parallel I cannot run the microwave and the air at the same time. With 3, no problem. Hardly a sag at all in Eco mode.
24 REPLIES 24
Fisherman
As for pairing up non identical or brand units it can be done. My son a an EU2000i and added a B&S 2200 inverter and they work fine together. Funny thing is his Honda will power up his compressor while the B&S will not even though it has a higher rating.
deltabravo
2oldman wrote:
I ran it alone and didn't really hear much difference. The on/off switch has a 'click' on it to turn off.
I have the all new EU2200i and it sounds the same as the many EU2000s I've owned.
Here's a video on it.
Fisherman
2oldman wrote:
CA Traveler wrote:
As often happens on these threads other topics are introduced. And that includes battery posts including at least one by you.
I give up.
You're supposed to say "Uncle"
2oldman
I give up.
CA_Traveler
2oldman wrote:
CA Traveler wrote:
Parallel DC sources of the same voltge is NOT like parallel AC souces of the same voltage..
Then I still don't know why you made that post about the batteries.
2014 Grand Cherokee Overland
Bob
2oldman
NRALIFR wrote:
If I could verify that the full combined running wattage were available if it was paralleled with a Honda 2200, that would be the best setup for me.
I can't state with 100% certainty, but I am comfortable in saying the chances are very good it would work.
There are some youtube's on pairings of different sizes, but I didn't find one for that specific combination. I do seem to remember a 1000 with a 2000 some time back.
Asking Honda is an option, but even then I'm not sure their tech support would approve of it, as they don't approve of making your own parallel cables.
NRALIFR
โ€œ Check your Yamaha and any other gen first before connecting in parallel.โ€
Yeah, I already know my Yamaha canโ€™t be paralleled with anything, but the Honda 1000 can, which is also rated for 900 watts continuous. If I could verify that the full combined running wattage were available if it was paralleled with a Honda 2200, that would be the best setup for me.
Really, Iโ€™m just looking ahead to the day when the built-in Generac 3600LP goes casters up. I only occasionally use it, but itโ€™s just a matter of time before some critical component fails, and Iโ€™ll find out that it either costs more than the generator is worth, or itโ€™s made of unobtanium. Itโ€™s been out of production for several years now, and even the used parts are drying up.
2001 Lance 1121 on a 2016 F450 โ€˜Scuse me while I whinge.
And for all you Scooby-Doo and Yosemite Sam typesโ€ฆโ€ฆโ€ฆ..Letโ€™s Go Brandon!!!
2oldman
CA_Traveler
NRALIFR wrote:
2oldman wrote:
NRALIFR wrote:
in other words, the paired generators will share the load equally up to the point where the lowest rated unit hits its limit, and then stop.
I have no way of measuring whether that's the case.
I do know that parallel sources (at least in DC) will contribute what they are capable of, independent of the others, whereas series connected source ARE limited by the smallest amperage unit. The triple parallel kit link shown above seems to say what I think.
Good question, but so far I can only speculate. Zia is in heaven camping in tall grass and hunting mice.
Thank you, and time2roll.
Not having any personal experience with parallel genโ€™s, I wasnโ€™t sure. It was just something I remember reading that of course I canโ€™t find now. Anyway, that would actually be ideal for me if you could connect a smaller and larger unit together, and have the full combined running wattage of each available for use. The vast majority of the time, the 900 watts available from my Yamaha is plenty. Itโ€™s only if I want to run the air conditioner though, that I need much more than that. Iโ€™d prefer to use a smaller, lighter unit most of the time, and then connect a ~2200 watt unit to it only when needed.
Tell Zia that Kahlua, Selina and Dixxie say hello :W
Parallel DC sources of the same voltge is NOT like parallel AC souces of the same voltage. AC voltage varies from + to - and connecting parallel souces MUST be coordinated so that the 2 frequencies and phase relationship are in sync. Few gens have this capability. Check your Yamaha and any other gen first before connecting in parallel.
The Honda website specifies which models AND SERIAL NUMBER RANGE can be paralleled. And there is a required procedure for connecting them in parallel, first shut down all gens, etc.
Bob
NRALIFR
2oldman wrote:
CA Traveler wrote:
Read up on how to load balance wire 2 batteries in parallel. This is the best way especially for 2 new batteries. Might as well do it right the first time.
I'm not sure what this has to do with my post.
:h I thought it was just me.... Glad i'm not alone
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
2oldman
CA_Traveler
OK, Hook up your 2 batteries in parallel, add the inverter and see how that works out which will help to determine your future upgrades and as such is a resonable plan.
Water pumps use very little power because they don't run very long. My coffee pot uses 1025W or 8.5A AC. That's 95A DC for say 15 minutes is about 24Ah, a significant draw. And with your small batteries the voltage may drop enough that the inverter shuts down. Especially in the morning after a nights battery usage. I have no experience with anything smaller than 2 GCs but others are better informed.
Bob
time2roll
NRALIFR wrote:
Interesting. I have a question regarding pairing of generators that ARE NOT identical in terms of running watts rating, as you are doing here. I seem to recall reading somewhere that your combined running wattage is going to be limited by the LOWEST rated unit in the pair, or of the three as you are doing.
In other words, the paired generators will share the load equally up to the point where the lowest rated unit hits its limit, and then stop. The higher rated unit(s) will not be able to take on an unequal load.
Can you comment on this? Does that appear to be the case with your units?
Have read plenty of posts that say all will contribute max wattage just fine. A 1000 and 3000 paralleled is not limited to 2000 watts.
The generators ramp up power as the voltage drops. At idle hondas are 125/127v and as more power is demanded the voltage drops until maximum output. I don't know the voltages exactly but consider for every 1v drop they add maybe 10% power. So as voltage approaches maybe 115 they are all running 100%.
