gemsworld wrote:
Thanks for posting the list. As I suspected, all but one of the stations in CA now sell B20. In AZ, only 3 stations show B5 and the rest don't say the type of diesel being sold.
No problem.
You know you can use up to B20 in the MB V6 as long as you keep an eye on the oil level, and some owners have said they shorten the oil/fuel filter and oil change intervals.
MB lays it out in the OM under (go figure) "B20 fuels with bio-diesel content" fuel.
In my 2017 Sprinter manual it's a short blerb on/near page 275.
! Continuous use of B20 fuel can lead to fuel
filter clogging and injector deposits. This can
cause engine performance degradation.
Injector deposits can cause the engine oil
level to rise due to unburned fuel washing into
the oil pan. This can cause engine mechanical
damage.
To avoid damages and performance degradation:
- Fill up with ULSD (B5 or less) whenever
possible.
- Regularly monitor your engine oil level if
you use B20 fuel on a regular basis.
- Strictly follow the oil change intervals quoted
in the instrument cluster and within
your maintenance booklet.
- Use only engine oils and filters approved for
use in your vehicle.
- If you do not plan to drive your vehicle for
several weeks, fill your vehicleโs fuel tank in
advance with ULSD fuel.
For more information, consult the gas station
staff. The fatty acid methyl ester B5 or B20 label
on the fuel pump must clearly state that the
standard for ULSD is complied with. If the marking
does not make this clear, do not refuel from
that pump.
Do not refuel with any fuels that have not been
approved for your vehicle.
For more information about refueling
(> page 125)."
Mike. Comments are anecdotal or personal opinions, and worth what you paid for them.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
