Help - How To Remove MaxxFan Fan Blade
JoeDog007
Hey All,
I am in the process of cleaning my MaxxFan exhaust fan in the bathroom and found that is nearly impossible to clean the fan blade without removing it. I purchased the 2016 3160RL brand new so I figure the fan blade has never been removed. I removed the 3/32" allen set screw that appears at the bottom of motor shaft. I have applied a little downward pressure and the fan blade will not budge. I don't want to apply to much downward pressure because I am afraid that I will break the motor support bracket. I am stalled in my cleaning. Please help - thank you in advance.
2 REPLIES 2
Dusty_R
Check and see if there is a second set screw in the same hole.
MrWizard
Moderator
Moderator
try some kind of penetrating fluid
like "break free"
om top of the fan hub so it can seep down the shaft
or spray in the hole where you removed the allen screw
I can explain it to you.
1997 F53 Bounder 36s
