As the other person said, Roughly as hard as hooking up a garden hose to the park water spigot.
TURN OFF WATER (or bypass the water heater) turn off heater, Remove drain plug and replace with a short tube so as to get water out past the edge of the RV. remove TPR valve (unscrew) go to Lowes, home Depot, Sears, Joe's hardware, most any plumbing supply, Hand to customer assistance clerk, get new one, pay, screw back in (Brass should not need tape or putty but you can if you like) remove drain tube, replace plug (See above comment applies to nylon as well)
Restore water, restore power.
