โAug-25-2015 06:46 PM
โAug-26-2015 04:39 PM
โAug-26-2015 04:06 PM
smkettner wrote:
Now we are getting somewhere. For float service set the supply at 13.30 volt in normal conditions and let it sit. For fast charge set to 14.8 volts and give the timer a twist from 30 to 180 minutes depending on level of discharge. (about 10% to 50% discharged respectively)
I am not an expert on Megawatt so now everyone can jump on me with corrections. :B
Not sure how the meter fits in.
โAug-26-2015 03:38 PM
โAug-26-2015 03:09 PM
โAug-26-2015 03:07 PM
MiPaJacks wrote:
Guys, I know not to play in your sandbox. My skill set is far below yours.
I have a 97 Holiday Rambler Vacationer with two 6 volt off the shelf batteries, It has the original not-smart charger, I think I can do better, therefore I read with interest Mex's sticky (to be) and his informative post on battery charging.
I followed the various posts on 8/18 and figured I could create a better charger based on your collective knowledge.
As listed by Ninerbikes in a post on 8/18 I ordered:
Megawatts 36 Amp supply
Watt Meter fron China 60W 100A
Mex's intermatic Timer 4 hr.
Jumper cables (cut off one end)
I learned from Landryacht today to use Power Poles to connect the various cable (Thanks Landy)
I have spent many years reading and educating myself on here, I know the pecking order.
Thanks for everyone's help
James
โAug-26-2015 03:00 PM
Vulcan Rider wrote:MEXICOWANDERER wrote:
So a person purchases a "high-end" smart charger and it does not charge the batteries. Where do they go from there? Exactly where do they go from there?
You continue to make claims that are not supported by the evidence.
Just exactly what name brand, "high-end" smart charger do you know of that "does not charge the batteries" ?????
Except maybe when they have been discharged to the point of being totally flat, that is. If and when that happens, it is a mistake which hopefully won't be repeated very often.
โAug-26-2015 02:48 PM
โAug-26-2015 02:41 PM
โAug-26-2015 02:08 PM
โAug-26-2015 02:04 PM
smkettner wrote:
That is the trouble. We don't know the starting point or the expected destination.
All we know is that the OP is in Dallas with a Megawatt of some rating, a meter of some sort and some jumper cable.
โAug-26-2015 01:40 PM
โAug-26-2015 01:05 PM
โAug-26-2015 10:50 AM
โAug-26-2015 10:15 AM
MiPaJacks wrote:
I ordered the Megawatt, meter, jumper cable, I assume they go in a line, but how do you attach the cables together? I may understand how to do it when I get all the parts.
I will never know as much as the resident gurues have forgot, so I will try to just tag along and not get in the way!
Thanks
James
