LED Lighting Diffuser Products
MEXICOWANDERER
These are thin, flexible (cut with scissors) translucent sheets that soften LED emitter glare and do it without chopping the snot out of overall light transmission (Lens that forces a bright light go dim).
One part number scatters light wide, while another part number focuses light into a narrower beam (like what is needed over a dining table).
This may be worthwhile chasing down a distributor via the website. I definitely would NOT recommend using these diffusers with an incandescent light bulb.
http://www.luminitco.com/
2 REPLIES 2
MEXICOWANDERER
It really helps - especially with LEDs that have garbage grade lenses.
Chris_Bryant
That's what we used on the makeup lighting- binned strips in aluminum channel with the diffuser covering.
-- Chris Bryant
