โDec-08-2015 01:13 PM
โDec-10-2015 02:34 PM
โDec-10-2015 01:59 PM
โDec-10-2015 01:10 PM
โDec-10-2015 12:26 PM
โDec-10-2015 10:51 AM
โDec-10-2015 10:40 AM
โDec-10-2015 09:45 AM
BFL13 wrote:
Sounds good, but I expect "SG lag" to ruin that plan. Worth a try at home for a test run though.
http://www.engineersedge.com/battery/specific_gravity_battery.htm
โDec-10-2015 09:31 AM
โDec-10-2015 09:22 AM
BFL13 wrote:
So, if you don't have enough charger/generator to get the batts to instant Vabs, can you apply this idea when there is a time while the battery rises to Vabs and then starts the absorption stage? I think I missed that info exactly.
So if I am doing my 50-90 and it gets to 75% when the battery reaches 14.8, I should lift the caps and start looking at bubbles. If it is only bubbling hardly any, I can keep going at 14.8 till it is bubbling "lightly" and then drop the voltage. So now I am at maybe 80% SOC, then do the 80-90 at the lower voltage? (but same amps into the battery so no time is lost?)
Or is it too late because it will already be bubbling "lightly" when it finally gets to 14.8?
โDec-09-2015 03:13 PM
โDec-09-2015 01:29 PM
MEXICOWANDERER wrote:
Ummmm this is to assssume the electrolyte is not a component in determining impedance? The great error is this assumption. The resolving of which would require perhaps 20 samplings per minute to compensate and develop an algorithm. Are you ready to develop an impedance sampler/controller for the process of charging? I'm not. Try Sandia National Labs.
โDec-09-2015 01:00 PM
โDec-09-2015 12:46 PM
โDec-09-2015 12:33 PM
