Now -This- Is A 29,30,31 AGM
MEXICOWANDERER
Lifeline GPL-30HT Deep Cycle Marine Battery $380 ea
Voltage 12v
Length – in(mm)13.46
Width – in(mm)6.77
Height – in(mm)11.95
Weight 96.00 lbs / 43.50 kgs
Lifeline Battery Part Number: GPL-30HT Cold Cranking Amps at 32°: 700
Rated Cap. Amp. Hrs 20 Hr Rate: 150
Minutes of Discharge at 15 Amps: 555
San Diego Battery
11 REPLIES 11
MrWizard
Moderator
Moderator
yep.. i post that back on the previous page
i located these today but it will be a day trip overnighter to get some
12AVR145ET Alcaltel, telco service AGM weight 105#
145 amphr 8hr rate
160 ampHrs 20hr rate
$125 & tax & core
i'm thinking about two of then to replace the FLAs that keep wearing out
i also located these for $30 each, i sent an email inquiry about their service they have been in/used, at eight years old these are dated
but no answer yet
these are close..and four would be 240 amphrs for $120
provided they have any life ..left in them
I can explain it to you.
1997 F53 Bounder 36s
pnichols
I finally located more info on that C&D Dynasty MR490 AGM battery: It's capacity is 139 amp hours.
2005 E450 Itasca 24V Class C
wa8yxm
San Diego Battery
Well that's none of the above.. A 31 is only 130 amp hours at the C/20 rate normally. That said.. Looks like a dang good battery.
MEXICOWANDERER
Even my regular 31 is w-a-y too heavy for me. In for a penny, in for a pound. I would like to get a 2nd 31 to take home with me. The price of the T and the tall one isn't that much different. There are lots of muscle bound young men down here and that tall battery will pose no problem.
I shake my head when I get to the specification pages of batteries. Missing is plate thickness and sometimes even the weight of the battery.
"Hey how much horsepower does this tow rig have?"
"You don't gotta know that. It's proprietary information, anyway"
Wotta hoot.
pnichols
That C&D Dynasty MR490 is quite the AGM 12 volt battery ... 100 lbs. in about a Group 31 form factor!
I notice that it's recommended float voltage matches a stock Parallax converter's output voltage, too. This would mean no converter/charger change would be required in our Class C.
It never occured to me to use a UPS standby power battery in an RV. I may consider a couple of these, if I can locate them at the right price point and figure out how to lift it down into the battery well. So far I haven't been able to find an amp hour rating for this series of C&D batteries, though.
MrWizard
Moderator
Moderator
I think MR490
I've got four, got them four years come July
Did a load test on them about 6~8 months ago, still going better than any FLA I have used even the golf carts
I got them surplus down in Ocean side, Ca
I Would like to get some more
They have worked very well
pnichols
George ... you're also using C&D AGMs?:
- I'm thinking about replacing my two AGM batteries in a few weeks.
- How are your UPS batteries doing in your RV application? It never occured to me to use UPS batteries for RV power.
- I believe my Interstate AGM wheel chair batteries were made for them by C&D, but I'm not sure if Interstate sells them anymore or where to buy C&D labeled AGMs. Any ideas?
- What model C&D UPS AGM batteries are you using?
Thx ... in advance.
MrWizard
Moderator
Moderator
my C&D technology UPS agm's are 139 Ahr, 488w weigh 100# and are 10.93" tall
pnichols
That appears to be a fine battery. It's not new ... it's been around for a few years.
I notice that: It's pricing may shortly be bumping up against the lower end of lithium pricing, it may be a bit too tall for some RV battery boxes sized for the smaller 12V battery heights, and it's pretty heavy to be able to manually ease it down into the well type battery compartments in some RVs.
MEXICOWANDERER
From what I was lead to believe, this critter has .115" plates. Note the wimpy CCA.
landyacht318
http://www.lifelinebatteries.com/marineflyer.php?id=4
Drooling. Perhaps I can talk my friend into this battery over the 31 xt. That 22 Extra Lbs of lead is impressive.
