Oooooooo More High Amperage Gizmos!
MEXICOWANDERER
Super Heavy Duty pair of Red and Black Binding Post.
Brass stud, washers & nuts
Bakelite Insulators
Rated 200A
Mtg. Hole: 11.5mm
Stud Dia: 8mm
L: 56mm DIA: 21mm WT: .2
PAIR Red & Black $4.95
http://www.mpja.com/06-27-16.asp?r=386312&s=2
5 REPLIES 5
pianotuna
Nomad II
Nomad II
Mtg. Hole: 11.5mm = 0.4527559"
Stud Dia: 8mm = 0.314961"
L: 56mm = 2.20472"
DIA: 21mm = 0.826772"
Regards, Don
MEXICOWANDERER
I want those for my Samlex inverter connections. I like Bakelite! Phenolic plastic. Regular price for 1/4X 20 is $20.00 a pop.
MrWizard
Moderator
Moderator
i want those in 1/4-20 ASME, not metric
I can explain it to you.
1997 F53 Bounder 36s
MEXICOWANDERER
"NYANNNT ZOOT!
ยก YESSSSSS !
gotsmart
are they "Frankenstein approved"?
2005 Cruise America 28R (Four Winds 28R) on a 2004 Ford E450 SD 6.8L V10 4R100
2009 smart fortwo Passion with Roadmaster "Falcon 2" towbar & tail light kit - pictures
