permanent campsite electrical
lainiest
I want my own pedestal. Can I daisy chain off from the pedestal nearest my campsite?
Can I plug into the 50 amp space and run it to my own pedestal with a 30amp and 20 amp outlets?
I would be using a NEMA Box/Pedestal and running the wire in PVC pipe underground.
I have a 30 amp TT and would like additional 20 amps for outside use.
18 REPLIES 18
DrewE
What you're describing, if I'm understanding it, is not kosher per the NEC. An extension cord (which is what you're really talking about, assuming it's just plugging into the 50A receptacle on the other pedestal) is for temporary use, and so not put in conduit, buried underground, etc.
Current NEC code requires a 20A outlet (maybe a 15A outlet, actually) at every site with electric service, besides any 30A or 50A receptacle. That's little help for an existing installation where you don't have one.
pianotuna
Nomad II
Nomad II
The short answer is No.
Investigate how many pedestals are already on that "loop". You might get lucky (but you had better be a lottery winner).
Regards, Don
Lwiddis
โ€œCan I daisy chain off from the pedestal nearest my campsite?โ€
I would suggest a pro review your plan and if ok wire this, not you.
Sam_Spade
NO.
Not unless you can somehow guarantee that the pedestal you are bridging onto will never be used.
Why are you not permanently parking at one of the existing spaces ??
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
