Proposed Solar Install thoughts
AlbertaNewbie
Planning my solar install and here is what I'm currently thinking. Need opinions on the pros amd cons of my install.
morningstar tristar 45amp mppt charge controller with remote temp sensor and remote meter
250watt 24V panel (to start, will be going up to 1000w next year)
8ga wire from panel to roof mounted combiner box approx 5 feet
6ga wire from combiner to charge controller 6 feet
6ga from controller to batts with 45 amp breaker 6 feet
thoughts? anything you would change?
2014 Dutchmen 261bhs - 7200#'s loaded
2012 Ram 1500 SXT Crew Cab w/5.7L HEMI, 4x4 3.55 Gears
250w Conergy 250P 24v solar with tristar 45amp mppt charge controller
18 REPLIES 18
Golden_HVAC
240 watts is a pretty large panel. Are you sure that you have a 3' X 5 or 6' long area to put it in?
You might want to try more manageable 120 - 150 watt panels.
Also check out this website. SunElec.com
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
BFL13
I don't think 45 amps is enough for 1000w. (four 250s in series/parallel? ) Would be over 60a too. You could get another controller for the second string when that happens and put the two controllers in parallel on the battery bank. Must be a hefty bank!
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
12thgenusa
45 amp controller won't handle the 1kW upgrade unless you are planning more controllers in parallel.
2007 Tundra DC 4X4 5.7, Alcan custom rear springs, 2009 Cougar 245RKS, 370 watts ET solar, Victron BMV-712, Victron SmartSolar 100/30, 200AH LiP04 bank, ProWatt 2000.
1492
Moderator
Moderator
Moved from Forum Technical Support
