โSep-09-2015 08:45 PM
โSep-11-2015 04:54 PM
โSep-11-2015 03:25 PM
โSep-11-2015 09:34 AM
โSep-10-2015 02:16 PM
โSep-10-2015 08:23 AM
โSep-10-2015 08:04 AM
Vulcan Rider wrote:GlennLever wrote:
I agree, to me the diode does not make sense, why is it there?
The way the diode is drawn is non-standard but I think the only "arrow" that counts is the big one in the middle.
Then......the fan probably is supposed to run all the time that the A/C is ON.
And even if it is running all the time, sometimes when it doesn't need to, that should NOT be a problem unless you are driving in VERY cold weather.
Ivylog wrote:
In the drawing of the engine it shows a sensor in the side of the pipe (intake air after the turbo) near the intake manifold of the engine. If it has three wires (R, G, Y) then that's it. On that vintage engine the turbo boost is a tube running to the back of the injection pump, not an electric sensor.
โSep-10-2015 07:45 AM
โSep-10-2015 06:26 AM
โSep-10-2015 05:17 AM
Ivylog wrote:
The good news is it's not a Sauer Danfoss controller... $$$. I believe your sensors are normally closed so you get 12V to the fan solenoid which slows it down until needed. Looks like the air inlet temp sensor keeps the fan off when cool air is coming into the engine intake so bypassing it should not hurt anything... in fact I'm not even sure why it's needed. The Sauer Danfoss complicated system only senses engine temp which is what you've done in the last diagram.
*At some point (first diagram) they did not feel the need for a air inlet temp sensor. I do not think you need one now but if it's a reasonably price sensor... why not as it may sense the need for more cooling sooner than the engine temp sensor.
โSep-10-2015 02:23 AM
โSep-09-2015 11:36 PM
