Rear Camera Problem
RamblinFever
My Weldex rear camera worked fine until last fall when mice got into the ceiling and I suspect damaged the cable between the rear camera and the monitor. I installed a new cable and everything works fine except when I shift into Reverse the screen goes blank. How could a new cable connected only between the rear camera and the monitor change the function like this, and how do I fix it?
2004 Bounder 35E, W-22
2014 Honda CR-V, SMI brake
2 REPLIES 2
RamblinFever
Johno02 wrote:
If your monitor has two camera inputs. try plugging the camera into the other one. Mine did the exact same thing when the camera was plugged into the wrong input port.
Thanks - That was it. I have very poor access to the back of the monitor and did not realize that there were two inputs. I ran my fingers across the back of the monitor and found the other one.
Johno02
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
