Replacing two 6 volt house batteries with one 12 volt
Monaramblee
08 Holiday rambler Vacationer diesel
with two 6 volt batteries for the house and two 12 volt batteries for the chassis.
I would like to replace the two 6 volt batteries with one 12 volt marine/rv battery.
We dont dry camp anymore. Any issues with this idea?
2008 Holiday rambler Vacationer XL
340 HP Cummins
31 REPLIES 31
Monaramblee
I got the 12 volt deep cycle battery and it was a challenge getting the cables to reach the terminals. Had to install it on an angle but it worked.
340 HP Cummins
Veebyes
BFL13 wrote:
Honest question--I don't know---can a single 12 house as the Aux, start the Diesel engine, which now has two 12s for it, if those two 12s are dead?
It is all in the switching. Via battery switches you can use or combine any battery bank for any purpose.
I have a boat that had 6 grp 31 gel cell batterys arranged in 3 battery banks. I could use any of those 3 banks for starting, house or all together. The drill was to put all together when running & take one bank out of line when anchored leaving the amperage of 4 grp 31s available for the house. Something like having 6 6V GC batterys.
If you like to dry camp battery power & water capacity are king.
Boat: 32' 1996 Albin 32+2, single Cummins 315hp
40+ night per year overnighter
2007 Alpenlite 34RLR
2006 Chevy 3500 LT, CC,LB 6.6L Diesel
Ham Radio: VP9KL, IRLP node 7995
Monaramblee
Yes this is why i feel the 12 volt battery might be a better choice for me.
Thankyou to all for the feedback.
340 HP Cummins
valhalla360
Navigator
Navigator
If you are keeping the starting battery topped up, you should never need to break out the generator but yes it will work. Note: the typical generator 12v system is only 8-10amp and it's unregulated. OK in a pinch but it will be slow.
It's not so much 6v vs 12v for CCA...it's deep cycle vs starting battery. CCA correlates closely to the surface area of the plates in the battery.
- The 6v golf cart batteries are designed for deep cycle use in golf carts. They have a smaller number of lead plates but the plates are thicker. There is no harm in using them for starting but they won't generate as many CCA.
- The 12v starting batteries are designed to put out a huge boost of power to start an engine and then the engines alternator is providing the ongoing power. They have more but thinner plates. The extra plates provide ore CCA.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Monaramblee
Googled the cold cranking amps of 6 volt batteries and it seems that a 12 volt marine style battery will have double the cranking amps in the event it is needed to boost the engine. So half the working amps but double the cranking capacity. Is this correct?
340 HP Cummins
Monaramblee
Im parked seasonally currently but i was thinking that if and when the engine batteries need a boost, i would start the genny and put the external charger in to play. I do keep the engine batteries topped up with a solar panel while camping.
340 HP Cummins
valhalla360
Navigator
Navigator
Monaramblee wrote:
The 12 volt battery i have my eye on has 800 cold cranking power and 80 amp hours.
I dont know the cold cranking power of the 6 volt batteries.
Borderline for a diesel. If the main truck batteries are just down and you hook the battery up with thick jumper cables, probably will be enough.
If the truck batteries are completely dead, good chance it won't be able to do it.
The difference between gas and diesel: Diesel starters have to overcome much higher compression and they have to spin fast enough to self ignite the fuel/air mixture before the walls of the cylinder absorbs the heat generated by compression. Gas engines have lower compression to overcome and the spark is what sets off the fuel.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Monaramblee
pianotuna wrote:
BFL13,
Gas maybe, diesel very iffy.
Why not diesel? Cranking power?
I was thinking that a 12 volt battery might have more cranking power then a 6 volt if needed to assist in starting the diesel engine but im not sure.
340 HP Cummins
pianotuna
Nomad III
Nomad III
BFL13,
Regards, Don
Monaramblee
340 HP Cummins
BFL13
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
midnightsadie
X3 can,t beat wal mart, theres one on evvery corner.
RAS43
midnightsadie wrote:
go get a wal mart deep cycle marine battery biggest that will fit. been using them for years no problem.mine are four years old last month.
X2 Mine usually last 4-5 years and are reasonably priced and easy to find.
pianotuna
Nomad III
Nomad III
Any size agm or sealed battery.
Regards, Don
