I posted back in Oct 2014 concerning my tire wear. Here is the link:
http://www.irv2.com/forums/f116/your-thoughts-on-my-tires-223666.html
pic here: http://www.irv2.com/forums/f116/shocks-266051.html
I moved two of the 2013 original tires, which appeared to be ok to the rear axle, put a new tire and the unused spare on the front axle. I also had the tires balanced and started running around 105 psi in them I have run them around 5500 miles since then and noticed that the unused spare I put on the front axle had a couple of flat areas all the way across in a couple of areas about a foot apart. one of which is half way thru the tread. Since I have eliminated the balancing issue and tire pressure I am wondering if I might need to replace the shocks. How does a bad shock manifest itself in relation to tire wear? Your thoughts?
These are 17.5" Michelins on a fiver.
This almost looks like a skid. Is it possible that one wheel could lock up?
Thanks
2015 Duramax 3500 dually 4x4
2013 Excel Winslow 31RSE
TST tire monitor
Magnum MS 2012 inverter/charger
3-135w solar panels
Tristar controller
Trimetric monitor
4-6v Trojan t105 batteries
B & W companion 3000 hitch
