Solar Boost 2000E
Johnny_G1
Will the Solar Boost 2000E controller work with a 250 watt, 24 volt panel. a question for a friend after somebody climbed up on his mh and proceeded to jump on his 2 12 Volt Kyocera panels completely destroying them, he has a chance to buy some 24 volt panels but can' t afford to buy a new controller too. Thanks.
98 Mountain Aire 34' 210 Cummins Puller and 2001 dodge dully with all the toy's, 400 + hp pullin a 2001 32.5' Okanogan 5th wheel, new to us after 5 yrs with the 28' Travel Aire. Lots of fun.
2 REPLIES 2
MrWizard
Moderator
Moderator
if you are talking about the Blue Sky 2000e
yes it should, it will depend on the VOC 'open circuit voltage' of the panels
they will need to wired parallel not series
in series the total voltage will be too high, in parallel it should work
the max voltage for the blue sky 2000e is 30v
if the panels VOC is higher than that, he can not use those panels
I can explain it to you.
1997 F53 Bounder 36s
time2roll
No it will not work. Max Voc is 30v and your panel will be about 35 to 40.
http://www.blueskyenergyinc.com/uploads/pdf/Manual_BSE_SB2KE.pdf see pg 9
2000E is made for 12v nominal panels.
