โOct-18-2017 10:42 AM
โOct-19-2017 01:03 PM
Itinerant1 wrote:
... battery bank normally gets back to 95-100% even after a couple/ few days of playing catch up but in this location it's been getting to 70% (350ah) by sundown ...
That's what seemed odd to me that I wasn't gaining back the lost power after a couple days of heavy overcast and snow. The way I'm parked and the path of the sun is enough for the antenna shadow to stay on the panels a fair amount of the day.
โOct-19-2017 12:56 PM
MEXICOWANDERER wrote:
Where I have to park to eliminate solar-oven effect, I imagine I hear an occasional Tarzan, yell. Turning the entire roof of Quicksilver into an "Aircraft Carrier" would help reduce solar heating.
โOct-19-2017 11:50 AM
CA Traveler wrote:
Solar Panel Bypass Panel Example
Three 60 cell 30V panels with 3 bypass diodes in each panel. Each panel can be viewed as composed of 3 subpanels each with a bypass diode. As shown below the output would consist of 20+30+20 = 70V at the given amps. The amps depend upon the given light conditions.
Assuming 8A the output would be 8*70 = 560W for the serial panels. For parallel connected panels the output would be 8*30 = 240W.
With shadows on 7 of the 9 subpanels there would be 8*20 = 160W available for charging with serial panels.
Click For Full-Size Image.
โOct-19-2017 11:35 AM
โOct-19-2017 11:27 AM
โOct-19-2017 11:13 AM
liborko wrote:Panel short circuit is one way to test for Isc and along with Voc is a good indication of expected panel performance. I preform these tests on all of my new panels.
Solar panel is a CURRENT source. How much power(watts) does it produce when short circuit amps are say 8A and voltage is 0V?
โOct-19-2017 11:04 AM
โOct-19-2017 10:58 AM
โOct-19-2017 09:42 AM
pianotuna wrote:Activation of a bypass diode does not change serial panel amps, they do reduce the panel voltage. The MPPT CC controller output amps/power is reduced.
Itinerant1,
The problem is the shaded panel (if in series) limits the amperage of the entire string. Even if you only had the upright part of the antenna casting shade through put would be reduced. The only "fix" is bypass diodes between each and every cell.
So far as I am aware, only Unisolar ever did that--and they are no longer in business.
โOct-19-2017 09:16 AM
โOct-19-2017 08:20 AM
โOct-19-2017 07:37 AM
Almot wrote:There is nothing magical about bypass diodes in solar panels.
30% drop, and antenna shade probably didn't cover 28-29 sq.ft. (30% of 1,280W).
When I posted about this oddity in series panels few years ago, nobody believed me. People were talking about magical powers of bypass diodes, sheesh...
โOct-19-2017 06:18 AM
Itinerant1 wrote:
With the inverter and misc charging of phone, laptop or tablet there is always some small load (2-8ah). The battery bank normally gets back to 95-100% even after a couple/ few days of playing catch up but in this location it's been getting to 70% (350ah) by sundown and after the evening dinner, tv and morning breakfast/ coffee making the bank could be down to 35-40% (175-200ah).
โOct-18-2017 10:26 PM
โOct-18-2017 09:40 PM
