โNov-13-2017 08:54 AM
โNov-13-2017 06:49 PM
MEXICOWANDERER wrote:Some explanation here:
A Learning Moment For Mex...
With 240/50 rigs, is it a universal practice to enable all and everything but additional roof air conditioners when running on a single 120 vac leg? How is the shed of A/C power accomplished?
Thank You
โNov-13-2017 06:39 PM
Thank You
โNov-13-2017 03:55 PM
โNov-13-2017 01:31 PM
โNov-13-2017 01:00 PM
โNov-13-2017 12:17 PM
Thank You
โNov-13-2017 11:15 AM
DrewE wrote:
It sounds like one of the legs is not being connected for some reason. While it's possible that there's a contact in the transfer switch that is failing to make contact, there are also other possibilities to check.
It could be that your 30A to 50A adapter is broken and not supplying one of the two 50A legs with power. That should be pretty easy to check with a meter. It could also be that you have a broken connection at your shore power plug, or at the other end somewhere.
โNov-13-2017 10:45 AM
โNov-13-2017 09:26 AM
