Water Tank Level Sensor is Leaking
AlwaysDreaming
2017 Chateau or Fourwinds 22B class C
Water Tank Level Sensor is Leaking, anybody ever repair/replace one? See attached picture in the Thor Message Board Post below
http://www.thorforums.com/forums/f8/water-tank-level-sensor-leaking-10791.html#post105814
15 REPLIES 15
DrewE
Have you tried snugging the screw down a bit?
Typically these are little more than a screw stud and a rubber washer/seal that is expanded by tightening the screw. I haven't replaced one myself, but it sure looks like it would be a very straightforward job (assuming, of course, the tank is emptied below the level of the sensor probe in question). If the tank is cracked or something where the probe goes in, that's a somewhat different matter.
