Dec-09-2019 09:09 AM
Dec-13-2019 07:59 PM
gatorcq wrote:If I can redefine the "M" to mean mangled, I'll agree. My PD9160 will not supply its full power when powered by the kinda-sorta sine wave from the Onan microquiet. Driven by an eu2000i, it meets the specs.
MSW Vs PSW is the issue.
Dec-13-2019 05:11 PM
Dec-13-2019 02:39 PM
Dec-13-2019 02:17 PM
Dec-13-2019 08:47 AM
Dec-13-2019 08:22 AM
Dec-12-2019 04:09 PM
wa8yxm wrote:
One thing I mention When my Rig was new I sometimes charged batteries using a Generac 1000. this is a true 1000 watt continous device (at least mine was) and it powered my Progressive Dynamics 9180 with wizard and dead house batteries.. You even had enough left over to power a night light... (not much more than that) converter is rated 1100 watts at full load.
Now once the batteries fill up.. Well that genny is not good for much but then I could watch TV if I wished. not much more with just 1KW.
2KW i could nuke lunch.
Dec-12-2019 02:41 PM
Dec-12-2019 10:16 AM
jfak7670 wrote:
Not so long ago I bought a new Yamaha EF2000iSv2 generator. Maybe someone has already had an experience with this gen and can suggest how many appliances can I run with it?
Dec-12-2019 10:13 AM
midnightsadie wrote:
get a bigger gen set.
Dec-11-2019 01:17 PM
jfak7670 wrote:It's not polite to hijack another's thread. Start your own.
Dec-10-2019 07:06 PM
About 12 or 13 amps. You have to add up the amp draw for each appliance. If the batteries are low, the converter/charger may take up most or all of that.
I have the 2000 watt Honda. It is dedicated to charging low batteries, and nothing else. Everything else is on propane. No microwave while batteries are charging. No hair dryer while batteries are charging.
turn off the breaker if you need to run an appliance?
Dec-10-2019 10:01 AM
Dec-10-2019 08:37 AM
opnspaces wrote:
I'm curious what this thread comes up with. I get the same thing with my Honda eu2000i and the generator. I can hear the microwave running slower than normal and the interior light is dimmer as well. It doesn't matter if I switch the eco throttle off, nor does it seem to matter if I flip the breaker on the charger. I'm boondocking at the time so everything is on propane.
