2013 Laredo
haste_maker
I have a 2013 Laredo TT that is parked under a carport when not in use. Most of the brown paint on the front cap has faded away, I contracted Keystone about this problem & was told "it is out of warranty"
Has anyone else had a problem with this make/year TT? If so what did you do about the the paint problem?
Retried Teamster
2007 Allergo
1 REPLY 1
bexparza
We have a 2015 Laredo 314RE and the Nose Cap has started fading. It's Ya gel coat problem Keystone has been plagued with for some time. You can compound it out using McGuire oxidation removal with considerable work. We caught ours while it was under warranty and Keystone has agreed to repair it. Unfortunately the only permanent fix is to have the nose cap spray painted. Check on the Keystone Forum and there are numerous posting concerning this issue. I have checksd other manufacturer sites and this problem has occurred to them also. So sorry, I know how frustrating the problem is.
