Here is the instruction manual for the Carefree
Eclipse awning. Here is the
service manual that may have some useful info.
The manual says:
The upper mounting holes must attach into structure using the screws provided. If structural backing is not available for the upper mounting holes, it will be necessary to use the aftermarket rail extension so that the upper brackets can mount into the structural members at the roof line. and:
For the bottom 3 mounting holes: if mounting into structure, use the 1/4 x 1 1/2 screws; if not attaching into structure, use the moly rivets. Note that it says you need to use a rail extension if structural backing is not available so that you can screw into structural material at the top. If you can't screw into structure, you need to use moly rivets. I'm not familiar with the term "moly" but assume they mean blind rivets. If you have fiberglass exterior side walls, they have a layer of 1/8" plywood behind the fiberglass so rivets would work.
The installation manual seems to have conflicting info on screw length and size. The instructions say to use "silicone" caulk or putty tape. Silicone caulk on the outside of an RV is an absolute no-no. Either butyl tape or Proflex caulk will work to seal penetrations in the wall. The manual says the "moly" rivets are 7/32". That's a pretty hefty blind rivet and not sure where you'd get them except for maybe a Carefree of Colorado parts vendor.
If you get stuck on details, you might try contacting Carefree but they don't list a phone number, only email. We had a problem with a gas strut and they weren't of much help tho.
