Carefree electric awning question
SWoop2247
Does anyone lubricate the inside rails of their awning?
If so, what do you use?
I seem to have to "help" our awning when we start extending it outward.
Is this normal?
Thanks in advance.
Steve
2014 Dodge Ram 2500 4x4 6.7L Cummins
24K Curt Slider
2013 Heartland Sundance 3200RE
9 REPLIES 9
SWoop2247
Thanks everyone.
I will look at the gas shocks as well.
24K Curt Slider
Chris_Bryant
Iโ€™ll also point out extension is due to the gas springs. They do go bad.
-- Chris Bryant
SWoop2247
IB853347201 wrote:
Is this normal?
Is your battery low? These awnings operate on 12 volts, low voltage will cause them to stall on extension or retraction.
Definitely not low.
24K Curt Slider
Chris_Bryant
There is a cam type helper for metal wrapped awnings- it goes around the awning tube, and kicks it out as it rotates.
-- Chris Bryant
Dukecity426
I use slide-out lube for all the hinged and sliding parts. I also use the slide-out lube on the gas cylinder if so equipped.
2004 GMC 4X4 D/A CC SB, "Juice/Attitude", 4" SS Exhaust, AFE intake, 2018 Reflection 29RS, two AC's, Reese 16K Slider, Bilstein shocks, 2 Honda EU 2000i generators.
IB853347201
Is this normal?
2010 Suncruiser
MFL
Nomad II
Nomad II
Mine is a Dometic, but similar, and I use either silicone spray for lube, or WD40 to clean the move able joints. If yours is having a binding issue, between mounting brackets and arms, you may be able to push the whole assembly (while extended) in the direction needed, to relieve the bind. I had to do this once, after the wind had pushed it out of alignment.
The electric motors on these awnings do not have much torque/power.
Jerry
GrandpaKip
Mine was squeaking a bit. Hit it with some silicone spray. Allโ€™s quiet now.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
Chris_Bryant
I use LC Wax Alumaslick for awnings of all types.
-- Chris Bryant
