Frozen Hot Water
214skier
We have a Grand Design Reflection 308BHTS TT and have lost hot water while camping in 10'. Does anyone have any ideas for short term remedy? Interested in permanent fixes after we get home as well.
Thank you
2016 Grand Design Solitude 377MB
24 REPLIES 24
amandasgramma
Just an added fyi here. We thought our hot water line froze the other day. Turned out the annode was burned up......cold water ran, ansolutely no water in the hot water. ๐Ÿ™‚
My mind is a garden. My thoughts are the seeds. My harvest will be either flower or weeds
Dee and Bob
plus 2 spoiled cats
On the road FULL-TIME.......see ya there, my friend
Calicajun
We just came back from Klamath Falls, OR where tempertures were in the 20s (ok low 20s) and 3' of snow. Our water lines froze up once. Turned out the low end drain valves froze but with a little heat on the valves water was flowing again. Added installation to the valves and everything was fine, until the TT heater stopped working but that is another story.
2014 Heartland Wildness 2775RB, 2015 Ram 2500 4x4 Mega Cab
RoyB
I know in my off-road POPUP trailer I have wrap around storage areas from the all the way around the front of one bed under the wrap around seating and down the other wall all the way to the other bed.
I installed those small 2-inch round vents from LOWES between each compartment and then next to the entrance door I flush mounted a 12VDC axial fan. I can turn this on and pull air through all of my wrap around cabinets on the floor. This includes where the hot water heater and water lines run that run under the sink etc as well... I can open the shore power cable access door and pull in outside out air as well...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
214skier
beemerphile1 wrote:
matt_r wrote:
MFL wrote:
Normally you have an access door inside the trailer. If you leave this open to circulate warm air to the heater and pipes, it should help. You can use a fan forced electric heater, or hair drier aimed at the heater and pipes from the inside to thaw.
Jerry
Found it. I out an electric heater inside. I am guessing the issue is where the hot water line goes into the belly.
The system is designed for the pipes to be protected by the furnace. If you are using an electric heater the pipes will freeze because there is no heat circulating underneath.
Understood. We have been running the gas furnace continuously since arriving here. The electric heater which is now under our bathroom sink is entirely suplimental.
I am doubtful the electric heater will do much assuming the frozen spot is in the basement-- the hole is pretty small.
beemerphile1
matt_r wrote:
Jerry
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
WNYBob
You can try "instant hot water solutions" by adding a circulatin pump, which moves water from the hot water tank through the HW tubing and back to the HW tank via the cold water tubes.
Pump control could be thermostatic or timer.
214skier
Jerry
MFL
Nomad II
Nomad II
Jerry
Triker33
Hot water freezes faster then cold
Larry Full Time Since 99
1999 34Q Discovery DP ISB 275HP 6 Speed Allison
VMSpc | Pressure Pro
14 Lincoln MKS EcoBoost Toad
Click here to see where I am
beemerphile1
Hard to know where it might have frozen. Are you running the furnace and is the water heater turned on?
You might want to also post in the Grand Design forum.
