โJun-07-2014 08:44 AM
โJun-07-2014 09:47 AM
โJun-07-2014 09:20 AM
nomad297 wrote:
By the way he worded this, I think the OP is under the impression that his hot water is timed -- that the water heater turns on when there is a demand and then turns off after a certain amount of time, giving him cold water. I am not sure he understands there is a finite amount of useable hot water, whether 6 gallons, 10 gallons, etc.
Is this the case, OP?
Bruce
โJun-07-2014 09:19 AM
Fishinghat wrote:
Since you've run out of hot water so quickly, it may be due to having the winterizing valves turned the wrong way. That causes the cold water to enter the top of the tank and almost immediately mix with or replace the hot water. So, check your valves.
Second, most experienced RV'ers take "Navy showers", where they turn on the water, get wet, turn off the water, soap up, then rinse off. This reduces the amount of water used considerably.
โJun-07-2014 09:09 AM
โJun-07-2014 09:08 AM
โJun-07-2014 09:05 AM
โJun-07-2014 08:48 AM
