Mounting P4500i Onan Generator
Jspool
I am going to mount an Onan P4500i generator on a tongue mounted platform on my Cougar 22MLS trailer. I do not readily see an easy way to do this. I have a generator box and four vibration isolating mounts to mountbit with. Has anyon already done this that can help with a suggestion?
Thanks
2 REPLIES 2
Lantley
This is an old post of mine. My last TT had a 4300 Is Robin Subaru genset ted on the rear
Rear Genset post scroll down
wanderingbob
Not that generator , not that TT but I have twice mounted gens on the tongue ,. Got 2x2 angle at Tractor Supply , had a welder fasten the angle in correct position to set the generator feet into . Never used isolating mounts , vibration was not a problem .I bolted it down and also added a motorcycle security lock .
