Nail in tire, Repair or Replace
MorMJS
Found a nail in my passenger side rear tire. Its not losing air quickly at all, about 4psi in 3 days. Should I just repair or should I replace that tire all together? Tires are Westlake Super ST205/75R14
This is my first TT and first tire issue so im not sure what common practice is.
**nail is through the tread
TV- 2009 Dodge Ram 2500 crew cab 4x4 6.7L CTD, 2" lift on 35x12.5" Toyo MTs, S&B CAI
New TT 2016 Keystone Bullet 272BHSWE Fastaway E2 WDH, Tekonsha Primus IQ brake controller
Old TT- 2014 Rockwood MiniLite 2502s
15 REPLIES 15
romore
If the nail is through the tread it is easy enough for a shop to patch from the inside. A plug will get you to a repair shop but is not intended as a permanent repair. If through the sidewall you are looking at a new tire.
