new 2 me 1977 prowler i know nothing
bschoolz
i just picked up a 77 prowler im putting it on my land with no power my 1st ? is can i use a battery to run the lights and water thanks for any help also how do you fire up the furnace
18 REPLIES 18
1911_F-350
Look into solar power to help keep the batteries charged.
06 F-350 DW 4WD
2016 Conquest 260RSL
gbopp
Welcome to the forum.
Check your roof for leaks. A small leak can do a lot of damage if not repaired quickly. Water intrusion will destroy a RV.
X2 on the two 6 volt GC batteries.
Rolling_Condo
The furnace should fire up when you turn it on via the thermostat. Turn the propane tank on and light a burner on the stove to purge air from the line.
'90 GMC R2500 7.4L w/ Gear Vendor OD
'90 Avion 34V
Cummins Onan P4300ie
Pro Pride 3P
Prodigy
Rolling_Condo
Yes you can run lights, water pump and furnace off of 12V. But, you will need a generator to keep the battery charged. Even a 1000 watt model will do. Best suggestion would be a pair of 6V golf cart batteries in series. Strongly recommend that you upgrade the Converter to a modern 3 stage type.
'90 Avion 34V
Pro Pride 3P
Prodigy
