โJan-02-2017 09:33 PM
โJan-03-2017 04:30 AM
handye9 wrote:
Does the trailer have a battery on board?
If it does, that would be the most likely suspect.
Assuming there is a battery involved: Then have the battery load tested. (If you're new at this, label the battery cables to be sure they go back in the right place, and note the + positive / - negative positions on the battery)
While the battery is out, turn on shore power and check lighting.
Note: There are a few older converters that require a battery being installed, in order to power the lights. If your's is one of them, you'll need to wait until you have a known good battery.
โJan-03-2017 04:12 AM
โJan-03-2017 03:54 AM
โJan-03-2017 02:05 AM
