Non-potable water and clean water tanks
Jesshopes
We stayed at a campground this weekend and had already filled our water tank when they told us the water was non-potable. What do you do after this to make sure your tanks are safe?
3 REPLIES 3
beemerphile1
Dump the water and sanitize your system with potable water. You do sanitize every year, right?
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
dewey02
This isn't an unusual occurrance. Campgrounds should be doing a testing of their water systems on a periodic basis. Having managed a group of 25+ public lands campgrounds, it was not unusual to get one or two "bad well" test results occasionally during the summer. We would post the well as unpotable and then shock the system with chlorine, followed by further testing. A clean bill of health would usually be recieved within a few days. The bad reading could be caused by many things. (usually a higher than acceptable total coliform bacteria count - this does NOT necessarily indicate E. coli bacteria is present). It also doesn't necessarily mean that the water is undrinkable, but may impact people with compromised immune systems, the very young, elderly, etc. A wise person would NOT drink the water, in my opinion.
Here is a typical report summarizing a season (from 10 years ago) for public water systems and what was done. 2006 Water Monitoring Report
As for your own FW tank and water lines, I would simply do as others have said. Just sanitize your trailer's FW system as you normally do at the beginning of your camping season. Then you should be good to go.
Dennis_Smith
Drain a cup of bleach let sit for a couple hours, drain fill drain a couple of times and your good to go
