Permanent Site Questions
On_theProwl
Hi all,
We currently keep our camper in enclosed storage, and pull out when needed for use. We have decided that we are going to go to a permanent site for next year. The camper will stay parked in the site 24/7, but we will also still be able to pull out for a couple of trips we take through out the year. Electric and water will be available from 4/1-10/31, which will be the months we visit just about every weekend. From 11/1-3/31, the camper will be winterized, but we will still be able to check on it or visit if we so desire, we just need to bring our own power and water.
This is all very new to me, so I'm looking for suggestions from some of you that already camp this way. I will list some of my thoughts and concerns below, and I appreciate any input you can give.
Tips on battling the weather since it will be outside 24/7? Especially over winter? The good thing is that the site is 85% shaded during summer months, but not much in winter after leaves have fallen. Invest in a good cover for winter?
Slides in or out when not there? Is this really a concern? I plan on pulling the slides in and out every couple of weeks just to keep them lubed, and I planned on putting the slides in over the winter.
Tips on battling the critters and bugs year round? I have no problems in our current indoor storage and never have had with any type of critter (Mice) or bug (Ants), but I'm sure that will change with the camper being stationery outside.
I'm sure I'll think of more later on, lol...thanks in advance for your suggestions!
__________________
2016 Jayco Eagle 325BHDS
2014 Ram 2500 CC 4x4 6.7 Cummins
3 REPLIES 3
LynnandCarol
when we park our trailer for long periods as we are now in Rockport, TX we use Home Defender bug spray around the trailer and all points touching the ground. You can also spread moth balls under neath to stop mice. we use nylon screen inside your fridge vent outside and the square holes in your bumper mount rubber ends (if you have). we also cover up our electric jack. if your tires will be exposed to the sun, I would cover those also.
Ron3rd
I would keep the slides in when not in use. They normally have gaps that can let critters in.
Equilizer Hitch
Honda EU2000
therink
I kept my rig at a seasonal site this summer. Just a simple do at home, inspect the roof and wash it regularly. The frequency that is needed to protect and keep it clean depends on the type of trees it is under (pine sap, seed bearing trees, etc).
I do not keep my rig there over the winter as I bring it home, cover it and leave it in my yard. If I were to leave it at my seasonal site for the winter (which I could if I chose), I would cover it just as I do at home. I would also make sure all underbelly and other holes are filled with steel wool to keep mice out.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5th Wheel, 12,280 lbs loaded (scale)
2015.5 GMC Sierra Denali 3500, SRW, Duramax, CC, Payload 3,700 (sticker- not scaled yet)
Take my posts for what they are, opinions based on my own experiences.
