Puma 31QBBH Grey Tank Size
mafitz
I just purchased a 2020 Puma 31QBBH TT. The brochure lists the grey tank size as 70 gallons... Awesome. However, this trailer has two grey tanks and one is soley for the kitchen sink. Does anyone have the same trailer and know the sizes of the grey tanks. My other option is to take a 5 gallon pail of water and fill up one of the grey tanks to determine size.
4 REPLIES 4
mafitz
Yeah not wild about having to hook up twice. I may figure out a way to tie the two tanks together. The pipes and valves actually stick out of the enclosed underbelly. I may try to run a pipe and tie them together.. I can't see the tanks to measure them.
cavie
the 70 gal is the total of the two tanks. I'm guessing 2 35's. If you can see them measure them and do the math.
2011 Keystone Sprinter 323BHS. Retired Master Electrician. Retired Building Inspector.
All Motor Homes are RV's. All RV's are not Motor Homes.
Lwiddis
rvusa says it has one grey tank, not two. https://www.rvusa.com/rv-guide/2019-palomino-puma-travel-trailer-floorplan-31qbbh-tr40555
Lwiddis
Ah, the fun of attaching the drain hose twice at each dump.
