replacing rear scissor jacks
kansas49er
Greetings. We own a 2004 Fleetwood Wilderness 250RKS Travel Trailer.
It is quite low to the ground, and if we go thru much of a road dip, one or both rear scissor jacks rub the ground. I have replaced one (left side) once already, and need to replace it again, as it bent on impact with a deep dip in the road. I am wondering if there is something else that I could use, like perhaps some sort of jackstand that was removable when towing down the road. Any ideas? Anyone?
Thanks so much for your consideration in answering.
Ed and Shirley
26 ft Wilderness pulled with Lincoln Navigator.
Fullon Newbie
2004 Wilderness 250RKS pulled by
2006 Lincoln Navigator
16 REPLIES 16
drsteve
Is there enough room to bolt something like this to the side of the frame?
2006 Silverado 1500HD Crew Cab 2WD 6.0L 3.73 8600 GVWR
2018 Coachmen Catalina Legacy Edition 223RBS
1991 Palomino Filly PUP
Hannibal
First thing that comes to my mind is, can you mount them closer to the rear axle? Do they have to be way out there where they can be damaged?
2020 F250 STX CC SB 7.3L 10spd 3.55 4x4
2010 F250 XLT CC SB 5.4L 5spdTS 3.73
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
2017 Jayco 28RLS TT 32.5'
